@vasqueso I DM'd you, as I don't want to saturate the forum with replies. Cool Stuff!
If the conversation might be useful to others, go ahead and flood us with replies :D. I've been silently keeping up on this thread to see what others are doing with this project. Still have my own half finished sunlamp.
Damn they pretty!!
What kind of colloidal silica did you use? When I searched for products, it seems like that there's quite a few different types, there's also powder types sold as resin filler for construction. It would help if you could tell me the specific brand and/or where you sourced it from too if you know it.
If one were to professionally manufacture a reflector into a say 30*60cm (1*2') or 60*90 cm (2*3') wall or ceiling panel, how thin do you think you could get it? And would you have to use a square panel instead or would rectangular do? And could you get the same effect with a square or rectangular reflector or does it really need to be circular? I don't think circular would be a nonstarter, but you would have to compress it to maybe no thicker than 3" for a wall panel or 12" for a sunken ceiling panel. I reckon though you could get it under 3" with a fairly small coverage area.
@curiouskiwicat a bit of napkin calculus tells me (if I've understood your question correctly): if you want a parabolic reflector in your ceiling to project light straight down, with a light source no lower than the rim of the parabola, then the depth has to be at least 0.2x the width. That is, if you want a parabola 30cm across, it has to be at least 6cm deep.
https://m.youtube.com/watch?v=qi8jmEbWsxU&t=331s
Apparently you can see Tyndall scattering in some glass ceramics, in this video with a zerodur dichroic mirror
Guys and girls, we have a chinese fan, check this out: 18:02
Hey everyone,
I was hoping someone could help me on my journey to recreate this project. This year in February, my hometown which gets dark early in the winter, had rough weather and had no direct sunlight for 21 days! Now I want to try recreate this project for the upcoming winter.
I have the dishes, the vinyl and a glass panel which I will experiment with. I was hoping to get some advice on the LED.
My dishes come with the receiver (pictured). Do you put the heatsink within or build a new housing for the heatsink? Also I'm very new to LED and electrical work so would appreciate any help here. Is it a 300w led that's used in the video? Could I use a lower wattage?
Thank you all
I got a scattering sheet from China, it's legit. The blue film is for protective purposes as seen on the first image. However, I wonder if it could be used to amplify the illusion of a blue sky, I put it back on for the second image.
I currently don't have it with me since I am away from home for college, but hopefully I can bring them with me when I visit my parents.
In time for the end of DST in Europe, I present my latest experiment in cheap-ass sunlight vibe simulation.
A high power bike light (I'm guessing 700 lumen) pointed at a 6" fisheye mirror, taped off into a square, on the end of a gooseneck desk clamp.
It throws a decently hard-edged square light, and shadows within the light are crisp, but it's acting as a point source so I'm sacrificing collinear light for coverage. It's not very intense either (a flat mirror would make a smaller but more intense light patch) but I'm mostly using this while my daughter is napping in the room so I don't want too much light, just the "sun through a window" effect
Does anyone know how large the parabol antenna has to be? I found one that's 90 cm in diametre but am unsure if it's enough. Bonus question (from someone more interested/capable in building than science stuff): What effect does the size of the antenna have on the end product? Can one get a "bigger" sun with an antenna that has a larger diametre?
@austinboston I wondered if you ever got this installed and could post pictures? Would be really interesting to see.
