LED Mounting hardwa...
LED Mounting hardware
5 Users
(@mgualt)
[#2523]
I am interested in building a super bright LED panel, and I am investigating the possibility of using these "LED modules" like this panel module or this linear module (though I am interested in using the 98CRI versions).  The LED module has the advantage of snap-together connections, it already has an aluminium backing, and it will reduce soldering errors.
My question is what these modules are supposed to be mounted to. Is there some kind of standard mounting solution where these plug in? What should I search for in terms of power supply and dimmer hardware.
Finally, if I would like the dimmer to be controllable by a phone app (to get a "sunrise" effect in the morning) how should I go about doing this?
In this post, they seem to be using linear modules, which seem to be connected with some kind of standard wiring plugs, and they seem to be simply screwed into a backing plate.  If this is the intended way to use these linear modules, please let me know.
Thanks for your help!
M
Posted : 15/10/2022 2:55 pm
Topic Tags
(@mgualt)
Also, if there is reason to believe that the flexible reel 98CRI are a better choice than these linear modules, please let me know.
Posted : 15/10/2022 3:39 pm
DIY LED U-Home
(@diy-led-u-home)
@mgualt we recommend use our this SMD3030 LED Panel to DIY super bright LED panel, it's also very good. DIY Perks use our this SMD3030 LED Panel light as TV background light to DIY one super bright TV at outdoor.
Here is the link at our DIY LED U-Home store,  https://www.diyledu-home.com/products/diy-led-u-home-high-cri-ra-95-dc48v-5-55a-smd3030-led-chips-max-270w-led-light-panel-ultra-luminous-daylight-white-warm-white?scm=spz.search&ssp=spz&spm=..search.search_1.2
You also can use our Flexible High CRI 97+ Daylight White 5600K to DIY Flexible LED Panel Light, here is the link of our 97+ daylight white led strip light,
https://www.diyledu-home.com/products/diy-led-u-home-led-strip-cri-ra-97-99-smd5630-164ft5m-300leds-60ledsm-dc12v-10mm-white-pcb-flexible-ribbon-strip-for-diy-movie-television-photography-lighting-daylight-white-5600k?spm=..collection_e4176b30-1322-4283-a4bf-b8e25dd747a6.collection_detail_1.2&spm_prev=..product_2298af68-4fe1-41ae-ae32-7e1105805853.header_1.1&variant=9f687cc5-21b7-4b2a-90c4-4bfd81324e08
970x600 A+页面 UK
1500x1500 可购物的图片
970x600 A+界面
SMD3030 LED Panel Light 13
Best regards,
Bruce
Posted : 30/11/2022 10:46 am
(@lilon)
To build a super bright LED panel using 98CRI LED modules, you can mount these modules on an aluminum backing plate, securing them with screws or thermal adhesive tape for stability and heat dissipation. Ensure the modules are connected using the snap-together connections, which reduce soldering errors. For the power supply, search for a constant current LED driver that matches the voltage and current requirements of your modules, and for dimmer hardware, look for compatible LED dimmers that can be controlled via a phone app, allowing for effects like a "sunrise" in the morning. Consider using an app-controlled dimmer such as those compatible with Zigbee or Wi-Fi for seamless integration. When purchasing your components, ensure to include the cost of these items in your project invoice for accurate budgeting and record-keeping.
Posted : 20/06/2024 10:41 am
(@pop-alexandra)
Posted by: @lilon
That sounds pretty good, actually. Thanks for the idea!
____________
Alexandra Pop
Posted : 29/10/2025 1:41 pm
