DIY Camera Slider
DIY Camera Slider
(@blendertimer)
[#2528]
Thought I'd share my latest DIY project. This is by far the most difficult, exhausting, and injuring DIY project I've ever completed!🤣
IMG 7438
IMG 7440
All it is, is a simple camera slider, put together with all the garbage I found around the house.😆 It's basically just a carriage that rides on a track (just held down by gravity, or me if it's at a steep angle). The track is made from a 3ft piece of aluminum C channel and is held to the tripod with a wing nut. The slider is made from a piece of medium sized aluminum square tubing (with one wall cut out) and rides along the track on some ball bearings (from a 1950s piece of machinery lol).
It's mostly for use by hand but I did make a slow motorized module which can be attached and removed from the track. But the motor doesn't work super well as it's just two RC car gear boxes I pieced together. Hopefully I'll find a better solution in the future.
If you're looking for demo shots, you can find an Instagram reel I made here or some videos I've uploaded to Pixabay. (though they haven't gotten through review yet)
(also, this is my first post here, so I hope it's in the right spot!😆)
Posted : 28/10/2022 3:48 am
Nice one! The footage looks very smooth... pretty cool that you made it out of just bits and bobs you had lying around! Reminds me of early DIY Perks stuff 😀
Posted : 28/10/2022 11:22 am
BlenderTimer reacted
(@blendertimer)
@diyperks Thanks! It does bring back memories of early DIY Perks!😄
Posted : 28/10/2022 5:34 pm
(@latfab)
Love projects that are made from shait lying around.
Food for thought: You mentioned trying to motorise the slider. Don't even bother with that, unless you want to use it for time-lapses. It is legit pain in the arse to source proper motors, drivers and input, to create smooth camera motion, that you are able to track.
A better option is to use flyweel. With flywheel's inertia it is easy to smoothly sart and stop the motion and maimtain consistant speed of motion.
Picture for reference:
tumblr inline no40cswChu1tu8vw4 1280
Posted : 29/10/2022 12:44 pm
(@blendertimer)
@latfab No, I was just going to use the motor for timelapses. It works ok except for some reason the carriage rocks back and forth occasionally during the timelapse. And the motor takes over 4 hours to get the carriage across the entire slider, which is too long for most purposes.
Posted : 30/10/2022 3:19 am
