P-CS5 (Gaming PC wi...
P-CS5 (Gaming PC with PS5)
 Kai
(@kai)
[#2684]
Currently I'm building my first ever gaming pc and I intended to combine my PS5 as well. I'm using Lian Li O11 Air Mini as my case and PS5 disc edition to work on it.
I had fully disassemble my PS5, currently I'm thinking of using AIO cooler or any CPU air cooler before I dive into custom heat pipe/heat sink like Matt did on the PS5 tablet edition.
Here's my initial plan:
Use AIO cooler on PS5 processor, and 2 fans for the memory side(like Matt did).
Just wanted to ask, what would you guys used to cool PS5 if you're building this. (EK water block too expensive)
Posted : 22/02/2024 2:15 pm
Topic Tags
 Kai
(@kai)
Finally! It's here!
Check the link below for a teaser of my build! Can't wait to show you guys.
https://youtube.com/shorts/NXgVkUcgsNw?si=24LoIlupwoCDe5f0
Posted : 25/04/2024 6:21 am
(@seanjrrr)
Hi I built me a pcs5 as well I used the Corsair crystal 280x case with a ps5 slim digital I originally started with the original spider man edition disk ps5 but I didn’t want to deal with the disk drive but also I kept everything original I use the stock air cooling that came with the ps5 slim i have an exhaust fan to pull the heat out everything runs good but fans are loud I plan on changing the stock fan but not sure what to use I did recently purchase a Corsair h80s liquid cooler I may install that not sure tho
Posted : 02/12/2024 6:05 am
