Macbook Pro M1 16 i...
Macbook Pro M1 16 inch speakers: I need the cable to be longer so I can use the speakers outside of the Macbook enclosure
(@johnnydub)
[#2777]
I want to put a M1 Macbook Pro 16inch (without the screen) inside my Korg piano and turn the Korg into a laptop form factor with piano keys added on top. But I need the Macbook speakers to be on each side of the Korg's enclosure. The Korg is wider than the Macbook, so I will need to make the speaker cables that connect to the Macbook logic board longer. These cables are very small and fragile, how can I make them longer?
Thanks for the help!
Posted : 12/01/2025 8:46 pm
Photograph? I know what you mean about those wretched internal cables, absolutely nightmare. This is this is true cost of factory production where machines do all the really tricky work. I got a laser toy for the cat a week or so back (Ali) and it almost caught fire within seconds of being turned on due to poor quality soldering - and zero protection.
Amazing how much those little LiOn cells stink!
Posted : 12/01/2025 10:13 pm
(@johnnydub)
Sorry, here is a picture!
IMG 2249
Posted : 13/01/2025 6:58 am
No worries.
Um... figured that might be how they'd done it. Those are custom flexible ribbon cables, which means specially created boards if you wanted to break out the cables to something a "hooman" can work with. The clips are available but I don't know the pitch or type someone else might have an idea but without that we're on a hiding to nothing unfortunately.
This is the price of miniaturisation unfortunately.
Posted : 13/01/2025 12:54 pm
