Need ideas how to h...
Need ideas how to hold my LED panel to wood
 Rain
(@rain)
Hi!
I glued my LED strips to aluminim as can be seen on attached image. At first I planned to screw it to wood but then realized that my design would cause short circuit because my screws are too close to wires. And without 3D printer I can't produce non-conductive plastic alternatives for these screws. With my previous panel I used glue but it turned out it did not like thermal expansion of aluminium. Which is what I tried to fix this time by drilling a little bit larger screw holes in aluminium so that it can expand and contract but sadly now I am stuck again. Any suggetsions how to connect that LED panel to wood in a way that allows a little bit of thermal expansion and that is also fine electrically?
Β
Β
 LEDPanel
Posted : 09/04/2022 10:11 pm
Sandy
(@sandy)
You could use something like 3M VHB tape or just silicon.
I can't quite tell from the photo but is the problem that the screw heads are touching the LED circuit wires?
Posted : 10/04/2022 8:35 am
 Rain
(@rain)
How would I use silicon? I have no previous experience with that. You mean use this thing?
and then do borders with that?
yes the problem is thatΒ  if I was to solder wires it would touch screw head.
Posted : 10/04/2022 10:57 am
Sandy
(@sandy)
Silicon sticks to pretty much anything so you can literally just apply it to the back of the aluminium and then stick it to the wood. It's normally used as a bathroom sealant but anything that sticks to things can be used as glue 😊Β
The only thing is that it comes out thiiiiiick, like pretty much all gun adhesives. If you want a flush final fit I would be tempted to use the VHB tape.
People tend to think that tape isn't strong but it really is.
Posted : 10/04/2022 12:32 pm
Tim
 Tim
(@tim)
Posted by: @rain
Hi!
Β
Β
LEDPanel
you cab actually keep this design and be smart with the wiring. LED strips can be soldered on any exposed connection pad. The way I did mine was connecting them in the middle rather than at the ends
Posted : 15/04/2022 6:16 am
