DIY Epoxy Resin Riv...
DIY Epoxy Resin River Table: Materials, Preparation & Building Tips
(@aaawen)
[#2959]
I've been exploring different techniques for making epoxy resin river tables and wanted to share some useful considerations for anyone interested in trying this type of DIY woodworking project.
1. Choosing the Right Wood
Live-edge hardwood slabs are popular for river tables because their natural edges create interesting patterns. Before starting, make sure the wood is properly dried, stable, and free from loose bark or debris.
2. Selecting the Right Epoxy Resin
Not all epoxy resins are suitable for deep pours. For thicker river sections, choose a casting epoxy specifically formulated for the intended pouring depth.
Pay attention to working time, recommended layer thickness, and curing temperature.
3. Preparing the Mold
A well-sealed mold is essential to prevent leaks. Use suitable mold materials and seal all joints carefully before pouring.
Secure the wood slabs to prevent them from shifting or floating when the resin is added.
4. Mixing and Pouring
Follow the manufacturer's mixing ratio and instructions. Mix thoroughly, including the sides and bottom of the container, while avoiding unnecessarily aggressive stirring.
Pour within the recommended thickness limits, and allow sufficient curing time before removing the project from the mold.
5. Sanding and Finishing
Once the resin has fully cured, level and sand the tabletop using progressively finer grits. Choose a finishing method compatible with both the wood and cured epoxy.
For anyone researching resin materials and DIY crafting supplies, Bond Craftor has a selection of epoxy products and accessories worth exploring:
https://bondcraftor.com
Final Thoughts
River tables combine woodworking and resin casting, so careful preparation is just as important as the pouring process. Choosing compatible materials, controlling temperatures, and allowing proper curing can help avoid common problems such as bubbles, leaks, and uneven surfaces.
I'd be interested to hear what techniques others use for sealing live-edge wood or preventing bubbles in larger resin pours.
Posted : 19/10/2026 10:49 am
